pablohoney
Oct 28, 2020Luminary
Attached devices not showing yet again
Does anyone think Netgear will ever fix the issue that is devices which are connected to the network not showing in either the Orbi app or in the web based GUI? And before Furry 38 tells me to do a ...
Oct 28, 2020Guru - Experienced User
What FW version are you using?
There has been two FW updates that were just posted...
pablohoney wrote:Does anyone think Netgear will ever fix the issue that is devices which are connected to the network not showing in either the Orbi app or in the web based GUI? And before Furry 38 tells me to do a factory reset and reattach everything from scratch or do a re-boot - this is not a permanent fix as it still happens - why?????????????
pablohoney
I have a RBR 50 and 2 RBS 50
I’m on the latest official firmware on all devices i.e. 2.7.0.70
- pablohoneyOct 28, 2020LuminaryI note that the firmware I am on is US only. Why is that? I also see there is a subsequent firmware version available 2.7.1.60 US also but it’s just a security fix.
Why are these firmware updates US only?- pablohoneyOct 28, 2020LuminaryI should add that I am not in the US and the (US only) in brackets was not there when I updated my firmware.
So is 2.6.1.40 the latest firmware for non US customers?- FURRYe38Oct 28, 2020Guru - Experienced User
v2.7 versions are next generaion Circle and parental controls. I believe hasn't made Circle support out side of the USA regiona.
v2.6 is for everyone.
