pablohoney
Oct 28, 2020Luminary
Attached devices not showing yet again
Does anyone think Netgear will ever fix the issue that is devices which are connected to the network not showing in either the Orbi app or in the web based GUI? And before Furry 38 tells me to do a ...
Oct 28, 2020Guru - Experienced User
It still falls under the US region policy.
https://www.netgear.com/support/product/RBK50.aspx#download
Under Previous Versions...
pablohoney
I’ve downloaded firmware version 2.6.1.40 for my devices. Satellites first then the RBR 50 and rebooted the system. Will see how the attached devices list looks over the coming days/weeks as at the moment, it is correct.
- FURRYe38Oct 29, 2020Guru - Experienced User
Let us know...
