SLK-Purdue
Mar 22, 2020Luminary
Attached Devices Sorted by IP Number
I have a good number of devices on my home network. I manage then with static DHCP reservations and I wanted to be able to get an Attached Device display in the web ui sorted by IP number. The at...
SLK-Purdue
Mar 23, 2020Luminary
Got one report of problems that I think may be due to line wrap in the PDF. The important code should look like:
function ip2int(ip) {
return ip.split('.').reduce(function(ipInt, octet) { return (ipInt<<8) + parseInt(octet, 10)}, 0) >>> 0;
Array.prototype.keySort = function(key, desc){
this.sort(function(a, b) {
var result = desc ? (ip2int(a[key]) < ip2int(b[key])) : (ip2int(a[key]) > ip2int(b[key]));
return result ? 1 : -1;
return this;
CrimpOn
Mar 23, 2020Guru - Experienced User
SUCCESS! This is SO COOL.
Looking at the web page contents, I am tempted to think there might be a way to have two "Attached Devices" menu items on the main menu so the user could select one or the other. (Not brave enough to try that.)
There is a timer somewhere that defines how long Orbi waits between updating the display. Wonder if that timer is in NVRAM somewhere?
The reason I ask is browser dependent. When I open Attached Devices in Chrome, Edge, and Opera the screen refresh is really obvious. The entire column of device icons (the stupid new graphics that replaced our cool pictures) and Connection Status both flicker as they refresh every 7.5 seconds (on my Orbi). Really annoying. Strangely, Firefox does not. Perhaps there is some technology buried in Firefox that compares page changes and decide they are not actually "changes". So, for now I will stick with Firefox when looking at Attached Devices.
Thank SO MUCH.
- SLK-PurdueMar 23, 2020Luminary
Glad you got it working. I have a number of things on my list that I would like to change. Since we have a "stay home" order, I may get some time to work down the list. We'll see.
Thanks,
Scott
