SLK-Purdue
Mar 22, 2020Luminary
Attached Devices Sorted by IP Number
I have a good number of devices on my home network. I manage then with static DHCP reservations and I wanted to be able to get an Attached Device display in the web ui sorted by IP number. The at...
SLK-Purdue
Apr 02, 2020Luminary
SLK-Purdue wrote:Got questions about how I get the file into ORBI. Good question.
I use PuTTY so a copy-and-paste is pretty easy. Most other Telnet package have some sort of copy-and-paste function
(Updated - sorry vi is automatic for me and I forgot the required ":" to enter command mode.
1. Select and copy the entire file on the workstation
2. Telnet to ORBI and login
3. cd /www
4. vi new.htm
5. o command to get to "add mode"
6. paste file (right mouse click in PuTTY)
7 ESC
9 clean up first and last line if necessary
10 :w
11 :q
SLK-Purdue
Jul 07, 2020Luminary
I have verified this works with new firmware version 2.5.1.32
www dropbox com/s/svqx6020yq0avgh/DEV_show_device.htm?dl=0
