jneun
Feb 17, 2020Aspirant
Attempting to setup (old) RBR50, unsuccessfully
Attempting to setup an RBR50 that I purchased over a year ago. Initial setup appeared good. Now unable to access Advanced tab (via either Orbilogin or IP address directly). Additionally, firmware ...
jneun
I have tried the three browsers I have on the PC.
schumaku
Feb 17, 2020Guru - Experienced User
Vaguely remember this happened under some conditions. Any Internet "security" stuff intercepting the Web traffic probably?
I hope some Netgear moderator like Dustin_V has some more ideas for the recovery, so a newer firmware image can be installed.
- jneunFeb 17, 2020Aspirant
My apologies. I thought I tried w/ the AV off. I turned off the AV and was able to access the Advanced tab and subsequently update the firmware. Thank you for your help.
