Xerical
Nov 11, 2017Initiate
Authentication Error Occurred
My wife and I both have Samsung S6. Recently received an update to the phone and afterwards it no longer stays connected to Orbi. My Orbi is on version 2.0.0.74. I tried rolling back to 1.11.0.20 ...
shminger
Nov 20, 2017Initiate
FYI... The solution to turn off the 5GHz transmission under the Advanced Network Settings does work to temporarily resolve the connectivity issues described above. I performed this change this weekend, and my wife & I have had consistent connections to our WiFi since... after not having consistent connectivity for >1week (likely longer).
Though this is not a valid solution long-term, as we would like to take advantage of 5GHz connection speeds, atleast it's a stop-gap for now.
The right solution is for Netgear to fix the root cause issue.
bolingde
Nov 22, 2017Guide
I have the same "authentication error occurred" on my Samsung sm-g925v (Samsung Galaxy S6 edge) phone runnning android version 7. I've turned off the broadcasting 5g to see if that works. (I also told to to forget the connection during reboot of the orbi) I don't move my laptop around too much and my other devices are roku's, firesticks and xbox's that don't move either but since I haven't noticed a problem on them I do think it's related to Samsung (or at least the s6 being able to switch on the orbi). Others in my house have an iphone 8 and Galaxy 8 and I haven't heard of a problem with them but I don't know if they would notice anyway.
The problem seems new (like maybe the last month).
In the 10-15 minutes I've been typing and my phone since shows "connected" on my S6 wifi.
- JoelM3dNov 23, 2017TutorExact same issue with our samsung galaxy s6 edge phones.
All other wifi devices stay connected.- rajah22Nov 24, 2017Initiate
I have a Galaxy S6 that would not stay connected. The solution that worked best for me was to enable a guest network with no authentication and uncheck Enable SSID Broadcast. Then I just manually add the guest network into my phone. It's not the most secure solution, but it's been stable. Hopefully, a fix for this is coming soon.
- JoelM3dNov 25, 2017TutorI just swapped my orbi out for my old ASUS RT-AC66U set to ap mode. No loss of wifi on either s6's.
When I find the time I'll try orbi again but disable all advanced wifi settings and see if it helps.
Maybe I should just get a dedicated ap like a ubiquity ap pro.- FboyleNov 25, 2017Aspirant
I'm having WIFi authentication issues with my Samsung Galaxy S6 since the phone S/W update earlier this month. It appears to be a wide spread problem based on other messages on this community. If I reboot the phone WiFi does connect but it frequently drops out and I get the Authentication Error message.
Does anyone know if NetGear has acknowledged the problem and whether there is a fix in process?
Thanks,
Frank
