Xerical
Nov 10, 2017Initiate
Authentication Error Occurred
My wife and I both have Samsung S6. Recently received an update to the phone and afterwards it no longer stays connected to Orbi. My Orbi is on version 2.0.0.74. I tried rolling back to 1.11.0.20 ...
JoelM3d
Dec 09, 2017Tutor
Very interesting about the guest network workaround. Have you noticed any speed throttling compared to using main SSID?
What is working for me currently is using my router in AP mode and disconnect my satellite. Downside to this is parental controls are disabled.
When I get a chance I'll try it guest network in router mode.
not4u13
Dec 10, 2017Guide
I have not noticed any speed differential. I just ran SpeedTest from the Android app and it shows 92.87Mbps. A lot of variables influence the number, but it's certainly fast enough. I received a 312 yesterday. No configuration changes. Most everything I do with my smartphone though isn't bandwidth intensive. Even music streaming doesn't require much bandwidth and I only do that occasionally. All other devices remain on the main SSID. Only my smartphone is on the guest network.
