Xerical
Nov 11, 2017Initiate
Authentication Error Occurred
My wife and I both have Samsung S6. Recently received an update to the phone and afterwards it no longer stays connected to Orbi. My Orbi is on version 2.0.0.74. I tried rolling back to 1.11.0.20 ...
Magnaschnoodle
Dec 12, 2017Tutor
Bin_jammin, Agreed. This issue ONLY started when Samsung pushed through this update in November. Up until then, I never had a connection drop issue between my phone and my ORBI. Nothing else drops in the house because of ORBI. The latest update that they just pushed through did NOT solve the issue. Our iPhone users don't have this problem. Our tablets, computers etc don't have this problem. It's only the S6. So Samsung needs to fix whatever they altered so the phone is again compatible.
Fboyle
Dec 13, 2017Aspirant
As I stated in an earlier post the problem seems to be tied to the S6 phone update on 11/4 with S/W version G920VVRS4DQJ1. Since we have Samsung as the S6 owner, Google for Android and Verizon (in my case) as the service provider, how do we determine who owns the problem? For the short term I've moved to the guest network and it seems to be solid but that's obviously not the desired solution. I have all my other devices on the primary system and everything is solid.
- Bin_jamminDec 13, 2017AspirantFor the record, I'm on Sprint, so it's not a carrier specific issue.
- FboyleDec 13, 2017Aspirant
And of course I should have included Netgear as a candidate but from what I've seen in this thread Samsung seems to be the leading possibility.
- bolingdeDec 18, 2017Guide
I think it's a Samsung issue unless of course there is something that Netgear isn't handling in the protocal correctly. I have seen cases where within a standard some parts are rarely used so most OEM's never checks or them, but if one does, they don't handshake correctly.
I think this is not likely but I'd rather Netgear at least make sure it's not the case instead of just saying "well s6's will soon be gone anyway", because it could show up again if it's a protocal issue.
- Bin_jamminDec 18, 2017Aspirant
Like I said, I have a GS6 and have this issue, but I don't have any Netgear equipment. Not sure how this could be anything but a Samsung issue or anything to do with Netgear.
*** Also, I got pushed an OTA update yesterday, fingers crossed it solved the issue.
- bolingdeDec 22, 2017Guide
Just an update on this problem.
Recap: Samsung Edge s6 would lose connection with the orbi saying "Authentication Error Occurred". Suggested work around was turning off 5g. While this worked for the phone, in my case it seemed to cause connection problems with the satellites.
I turned the 5g back on, and created a test network. Issues with the satellites and authentication seems to have went away.
While I was almost sure this was a Samsung problem the fact that the phone works fine on the guest network points somewhat to the Netgear Orbi (because if it was just a samsung problem it would have the same issue on the guest network, something is different on the guest network that allows it to work).
- webminsterDec 22, 2017Luminary
I have a Samsung S5... funny thing is since installing the Orbi about 3 weeks ago, I hadn't had any auth errors on the phone - til today. Happened twice this morning. Only diff was reloading the .16 firmware on the Orbis to try to fix the attached devices issue. Not sure why this suddenly started again.
- not4u13Dec 23, 2017Guide
I have not tried to switch back from the Guest network since my last post, but I can say that my device has remained very stable since then and since I updated the Orbi to allow access to the main network from the guest network, I seem to have full functionality to control my various home automation systems from my smartphone as well.
While some are calling this clearly a Samsung issue, I disagree. This is an incompatibility between this particular Samsung device with this particular update and the Orbi device. I don't have any issues with my smartphone connecting to wifi reliably on any other wifi network. I don't have any trouble with my Orbi using any other device. Yes, this started occuring with the Nov 4 Android Update and no, the more recent update to the GS6 has fixed the issue. I actually have two GS6 smart phones and they both experience the same issue and both work just fine on the guest network.
I really have no idea why the guest network works and the primary network does not. I should add that I did enable security on the guest network as well, so it's not really a "guest" network any longer. All I can say is that this workaround works and I've seen no downside to using it. Now, if you do have guests and make a habit out of giving them the guest network wifi but don't want them on your primary network, this would not be a good workaround for you.
- p_hazeDec 24, 2017Tutor
I believe this issue is resolved. I recieved a software update on Thursday (S6 Active, on AT&T network). Since then my phone is connected to the main Orbi network and stable. I have not had to use the guest network.
It is a Christmas miracle.
- FboyleDec 30, 2017Aspirant
I received Android update G920VVR44DQL1 dated 12/28/17 for my S6 today (Verizon carrier). I'm still using the ORBI Guest network function since there was no solution regarding the authentication issue in the update.
- prasen82May 27, 2018Aspirant
this is not specific to samsung. i have the problem on my s8, fire tv stick and my macbook. so suspect problem is larger . new security patches on client devices are causing connection problems. my guess is something to do with same ssid for booth 2.4 and 5 ghz.
its a problem on both router and client side device.
