Doctorold
Mar 11, 2017Star
Authentication Required using Orbi with Google Fiber
So I bought the Orbi system and used it flawlessly with TWC cable internet. Took the Orbi to my new house where we had Google Fiber installed. Unfortunately, some web pages ask for username and pass...
Doctorold
Mar 12, 2017Star
There's no login required for Fiber. Unfortunately, Orbi hasn't been around long enough nor has Fiber to find more with same issue. Can't find any settings in Fiber setup to change the way they play together.
Mar 13, 2017Guru - Experienced User
You could use the google router, and then set up Orbi as an access point.
