GASkinner
Oct 29, 2018Tutor
Authorization requests (on public sites) after router reset.
I had to reset my Orbi router after an error from my PRovider (Bell). The setup went fine, connected to the internet, speed tests are good. My issue is that when I now try and use sites like BBC and...
- Oct 29, 2018
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Oct 29, 2018Guru - Experienced User
What browser are you using? Try IE11, FF or Opera to see if same thing happens?
GASkinner
Oct 29, 2018Tutor
Also:
Happens on browsers on my mobile device (iPhone and iPad), both will also now not run app updates as normal.
- FURRYe38Oct 29, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
