mkepeter
Apr 05, 2019Guide
Auto firmware update resets router to factory default settings.
The past two firmware updates have reset my router to factory defaults requiring me to reconfigure the router to my settings. All wireless devices are disconnected until I can complete this. The re...
mkepeter
Apr 06, 2019Guide
I did a 30:30:30 reset this moring. Noiw I'll wait for the next firmware update...
Apr 07, 2019Guru - Experienced User
Did you save a back up configuration to file?
Does the configuration persist thru a reboot or if you pull the power cable from the RBR and plug it back in?
- mkepeterApr 07, 2019Guide
yes on the backup of the configuration prior to the 303030 reset. I did a backup after the second time the firware update took the router back to factory default settings. I can power off and back on the router and my saved config loads.
- FURRYe38Apr 08, 2019Guru - Experienced User
Good to hear. Glad it's working now.
Enjoy. :smileywink:
