chouchou7
Jul 17, 2019Aspirant
auto sensing Ethernet port?
Hello, I setup the orbi with wired backhaul so I use one port to connect with the orbi router. But after I connect my device(PC) to the other port, the whole orbi system is down. I cannot get onli...
- Jul 17, 2019
They are...
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.Ensure the cable between the RBR and PC is of good working quality. CAT6 is recommended. Swap cables for testing.
Try different ports.
Try a different PC.
Are you connecting to the RBR or RBS?
Disable Daisy Chain if you have the RBS connected ethernet to the RBR.
Jul 17, 2019Guru - Experienced User
They are...
Try a different PC.
- chouchou7Jul 17, 2019Aspirant
Thank you, please see my setup below
What Firmware is currently loaded? Latest 2.3.5.26
What is the Mfr and model# of the ISP modem the NG router is connected too? Netgear CM500
Is the Orbi system operating in Router or AP mode? Router
What is the Mfr and model# of the ethernet switch if one is in the configuration. Netgear GS308PEnsure the cable between the RBR and PC is of good working quality. CAT6 is recommended. Swap cables for testing. OK
Try a different PC.
Are you connecting to the RBR or RBS? RBS, RBR connected to the switch, and RBS connected to the switch
Disable Daisy Chain if you have the RBS connected ethernet to the RBR. Will do
