chouchou7's avatar
chouchou7
auto sensing Ethernet port?
Hello,  I setup the orbi with wired backhaul so I use one port to connect with  the orbi router. But after I connect my device(PC) to the other port, the whole orbi system is down. I cannot get onli...
  • FURRYe38's avatar
    Jul 17, 2019
    They are...
    Is the Orbi system operating in Router or AP mode?
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    Ensure the cable between the RBR and PC is of good working quality. CAT6 is recommended. Swap cables for testing.
    Try different ports.
    Try a different PC.
    Are you connecting to the RBR or RBS?
    Disable Daisy Chain if you have the RBS connected ethernet to the RBR.
