OculusQuestFan
Oct 02, 2019Aspirant
auto switching to 2.4ghz when very close to router - why? RBR40
I have an Oculus Quest which can stream contents from my PC, but ONLY via 5ghz. For some reason the wifi keeps randomly switching between 5ghz and 2.4ghz, even though I am standing 10-15 feet from t...
- Oct 03, 2019
Thanks for the replies.
Sure, they might ask that question but since there is no way for me to modify the firmware of the Oculus Quest, it is pointless and submitting a ticket to facebook support will probably go nowhere.
What I can control (if netgear would let me) is seperating the ssids, which would solve the issue easily.
My first solution of disabling the 2.4ghz broadcast fixed the problem, but broke the couple of devices I have that only work on 2.4ghz.
My current solution is sideloading this app via sidequest: https://play.google.com/store/apps/details?id=com.seah0rse.swififree&hl=en_US
So far it's working great but not an ideal solution.
Oct 02, 2019Guru - Experienced User
There maybe noise or interferences that the your device maybe detecting and changes on it's own.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
I would also refer you to the devices Mfr to see if they have any recommendations to keeping the devcie from changing. It's up to the devcies to connect to a wifi signal based on signal and quality and noise.
You can turn down the power radio on the 2.4Ghz side from 100% to say 50% and see if this keeps your device on the 5Ghz frequency.
