OculusQuestFan's avatar
Oct 02, 2019
auto switching to 2.4ghz when very close to router - why? RBR40
I have an Oculus Quest which can stream contents from my PC, but ONLY via 5ghz.  For some reason the wifi keeps randomly switching between 5ghz and 2.4ghz, even though I am standing 10-15 feet from t...
  • OculusQuestFan's avatar
    OculusQuestFan
    Oct 03, 2019
    Thanks for the replies.
    Sure, they might ask that question but since there is no way for me to modify the firmware of the Oculus Quest, it is pointless and submitting a ticket to facebook support will probably go nowhere.
    What I can control (if netgear would let me) is seperating the ssids, which would solve the issue easily.
    My first solution of disabling the 2.4ghz broadcast fixed the problem, but broke the couple of devices I have that only work on 2.4ghz.
    My current solution is sideloading this app via sidequest:  https://play.google.com/store/apps/details?id=com.seah0rse.swififree&hl=en_US
    So far it's working great but not an ideal solution.
