Vphan13's avatar
Vphan13
Follower
Apr 27, 2018
Auto update 2.1.4 bricked my router?
My system auto updated sometime last night. . .came home to a not working wireless.  Rebooting both, and attempting to connect via a wired connection, I see the router IP pings only spontaneously now.   I can get to the web page sporadically, but not long enough to manually downgrade. I also noticed the ethernet backhaul no longer works.  Wondering now if my systems are bricked. . it was working flawlessy until this latest update.  I'm way out of the support period. . is there a procedure I should flow to try and fix this?
  • It's highy unlikely, that the fw update bricked your router. Have you tried to perform a factory reset? Depending on the fw release the Orbi has updated from, this might be necessary.
  • try unpluggin the satellite from the main router and reboot.  If everything comes up, then try plugging in the satellite.
