cdanthony
Aug 03, 2017Aspirant
Auto Update Firmware?
Hi, i just installed my Orbi router 24hrs ago. So far, so good. I was checking the firmware versions. My RBI is currently running 1.4.0.34. I noticed there is a much newer version out. Everything I'...
vtrusty
Aug 03, 2017Star
for what it's worth i first manually updated the firmware on both my router and satellite. ever since then it has been auto-updating (unfortunately) just fine.
go ahead and just download and update the firmware yourself
cdanthony
So...bad experience with firmware updates...not just the newest 1.12 update?
thanks for your response
