Funkyharlemite's avatar
Jan 23, 2018
Automatic connection
Good day,
I set up the Orbi system and added a satellite.  The only way that my mobile devices are connecting to it is if I turn off the WiFi on the device then turn it back on to have it reconnect to orbi.
How do I set the orbi for my wireless devices to remain connected, even after a period of inactivity?  I should not have to toggle my device’s WiFi button on and off every time I enter my place for me to have the WiFi working.
thank you
1 Reply
  • No setting on Orbi to affect this. Make sure you have turned off all of your old WiFi access points. If that’s not it, have your devices forget the Orbi WiFi and re add it.
