Daniel-UK
Dec 04, 2020Apprentice
Automatic email when new firmware is released?
How can I get an automatic email sent when ANY new firmware for my Orbi is released? The iPhone app or the web interface only show major firmware updates and while they show "No new firmware vers...
Daniel-UK
CrimpOn thanks for your useful answer. So far I reached the same conclusion that the most useful email notification is not available!
FURRYe38 sorry but your answer is not clear. Are you saying that you don't know if the answer is YES or NO but Blanca_O can help answering it?
vajim unfortunately NG does not pushes all the updates but only the minor ones. The last 2 updates both contain security fixes and were not pushed. So there isn't much to relax.. or to rely on NG doing the right thing..
vajim
Dec 04, 2020Master
That's not what they told me.
I don't do manual updates and my network has been fine for over a year. If you do a search in here you'll see where folks that download the latest and greatest FW when it first comes out end up reverting back because it was not ready for release.
You sound like you need the assurance of a newly released to make you feel good. That's fine for it's your network and you can do as you please.
Good luck
- CrimpOnDec 04, 2020Guru - Experienced User
vajim wrote:vajim unfortunately NG does not pushes all the updates but only the minor ones. The last 2 updates both contain security fixes and were not pushed. So there isn't much to relax.. or to rely on NG doing the right thing..
This is an example of how Netgear simply does not provide useful information to customers. "Security fixes" could be anything. (Important? Trivial? External threat? Internal threat?) Contrast that with how Microsoft categorizes security vulnerability fixes or with the very detailed "change logs" provided by packages like Wireshark, Pi-hole, Belana Etcher, etc. etc.
I have serious doubts that Netgear will ever "push" firmware to Orbi's again. Constant nagging (both web and "app") seems to be the future. And, I agree with vajim that every time new firmware comes out, the forum fills up with posts about things breaking and the solution being to "roll back."
- Daniel-UKDec 05, 2020Apprentice
CrimpOn your answer was VERY useful!
Do you know how to setup the Netgear router to intercept all DNS requests and route them to OpenDNN?
Many thanks
- CrimpOnDec 05, 2020Guru - Experienced User
Daniel-UK wrote:CrimpOn your answer was VERY useful!
Do you know how to setup the Netgear router to intercept all DNS requests and route them to OpenDNS?
On the Orbi web interface, the Internet Setup menu item, there is a section where you can choose:
- Get DNS server IP's automatically from the ISP, or
- Use these DNS servers, where you enter the IP's of two DNS servers.
If this option is greyed out,, it usually means the Orbi has Parental Controls enabled, and they have to be disabled to make the option available again.
