sross44's avatar
sross44
Follower
Jun 14, 2020
Automatic Reboot on RBK53 with dropped signal?
I have comcast with an ARRIS T25 cable modem. Comcast is horrible in my area and every few days my modem reboots itself because of the connection with Comcast. I travel a lot for work and have a lot of work files on my home network. Is there a way that every time the Orbi loses it's internet connection to set it to reboot somehow?
Right now when the modem resets, the orbi doesn't always pick up the signal.... not sure why, but hoping that I can figure out a way that if the modem resets itself that I still have connection with the Orbi so I can access files from outside etc.
Hope this makes some sense!
1 Reply
  • FURRYe38's avatar
    Have the ISP check the signal and line quality UP to the modem.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure your using good quality LAN cable between the modem and RBR. CAT6 is recommended.
    Try a different brand modem.
    What Firmware version is currently loaded on your Orbi?
