rongor's avatar
rongor
Availability internationally
I have a friend with a small hotel in Patagonia, Argentina. The wifi is delivered by satellite but the router is antiquated. Is an Orbi system available internationally.  Argentina uses 220v and a plug similar to Austrlalia
  • The power adapter is 120~240 vac. He may need a plug adapter, though.
    • schumaku's avatar
      schumaku
      Guru
      Some market supplied power adapters [Europe with the UK adapter] might be universal voltage, others [like the US] probably aren't.
      • rongor's avatar
        rongor
        Thanx for the reply
        Which Orbi would be best. The hotel is L shaped with the router at the foot of the L. I figured 1 or 2 satellities.
        Ron
