james4933's avatar
Jan 11, 2022
AX4200 satellite adding to AC2200
We purchased the Orbi Mini 2-pack AC2200 Tri-Band WiFi system initially.  Later I also purchased  an Orbi Tri-band WiFi6 add-on satellite.  Can I use this satellite with the system that I purchased?  If so, how to I add this satellite to the system?  Thanks!
  • plemans's avatar
    No. The AX satellites aren't compatible with the AC systems.
    • james4933's avatar
      james4933
      Guide
      So what satellite do I need to purchase to add an additional to the system?
      • plemans's avatar
        compatible satellites are:
        RBS20
        RBW30
        RBS40
        RBS40V
        RBS50
        RBS50Y
        You can also use the EX7500, EX7700, EX8000. they don't integrate with the system but they do work.
