mastervisa30
Mar 08, 2019Luminary
Back to the nightmare again on latest firmware
Firmware Version 2.3.0.32 didnt work for me,i have droops out all the time on my 2 satellites,
poor signal and not connected all the time,my kids and wife are going mad on me.have tried reset and a...
- Mar 08, 2019
I like orbi,but if im using older firmware now,does it auto uppdate by its self now?
I heard netgear have turn of auto in the system on latest firmware.
Im gonna try older firmware now and se if its auto uppdates its self now?
if we can use older firmware when other is buggy,then its gonna work :)
orbi is working great good speed when its working.
using firmware version 2.2.1.210 and no dropps out and all good so far.
Tried laetest one more time and droops out was starting.
So now im gonna try stay on firmware version 2.2.1.210 and hope it doesnt auto uppdates by its self.
mastervisa30
Mar 08, 2019Guru - Experienced User
Did you factory reset the Orbi system and setup from scratch after loading v32? Try this next time when you upgrade. This clears out possible problems after upgrading FW. Others are reporting good operation after ugprading to v32 and doing a factory reset and setup from scratch.
- mastervisa30Mar 12, 2019Luminary
sorry late answer,i always do factory reset,and new setup everytime i install new firmware its standard for me
:)im still on firmware version 2.2.1.210 no dropps out on my satellites
- FURRYe38Mar 13, 2019Guru - Experienced User
You might try a manual load of v28 again at some point. Good Luck.
- djkacMar 13, 2019Tutor
You shouldn't have to do a factory reset and setup from scratch every time. That's a huge pain in the arse!!
We know however it helps resolve some issue seen after doing a autoupdate and problems arise.
Users are reminded to also do a back up of the configuration to file so when a factory reset is needed, they can save time by loading the config from file. It's best to save off a new config to file after updating FW and after a reset and setup from scratch is performmed. Keep the configuration files with in each FW version. Some backups may not work well from older FW versions.
- PapaMikeMar 22, 2019Star
I've never had to do a factory reset after FW updates.
Last night, the .44 auto-updated and my system is performing BETTER than ever. According to the history on Orbi app, performance has increased a bit.
I've never had issues with router or satellites.
