MiCas
Apr 28, 2017Follower
Backhaul 5GHz vs 2.4GHZ i.e. Speed vs Distance
Netgear declare that “dedicated 5 GHz band with up to 1733 Mbps that is used solely for communication between an Orbi router and satellite”. My question is how good the 5GHz travels acros walls/flo...
TheEther
Apr 28, 2017Guru
In general, 2.4 GHz has better range, but in many cases that is more than offset by the superior signaling technology used by 802.11ac, which is only available at 5 GHz. At distances where 5 GHz can maintain a connection, it will almost always be faster than 2.4 GHz. The 5 GHz spectrum is also less heavily congested.
