Uso68
Jun 23, 2018Tutor
Backhaul breaks the whole network
I have the RBR50 with 2 satellites RBS50 running on the latest firmware V2.1.4.16.
I'm running in router mode.
The Orbi router is connected to the ISP modem on the yellow WAN port, and one of th...
standarduser73
Jul 10, 2018Tutor
I too am having issues with ethernet backhaul. It was working as expected prior to updating to 2.1.4.16. However, since the update, connecting the satellite via ether takes down the network. Just using some basic troubleshooting techniques, ping is constantly dropped when the satlleite is connected via ether. But ping isnt just dropped to the satellite, it is dropped to the router as well. With a client directly wired to the router, ping drops to the ROUTER when the satellite is connected. Something is definitely not right. The satellite is directly wired to the router. I have tried several configurations, and the results remain the same. Dropped packets, connectivity issues, etc. The wireless backhaul is great and all, but in my house full of plaster and chicken wire, each room is essentially its own Faraday Cage. This makes the wireless backhaul sketchy at best. Seeing this seems to be systemic issue, when can we expect Netgear to release a new Orbi firmware? If there are any beta programs for 2.2 available to sign up for, I will be happy to be a guinea pig.
- FURRYe38Jul 10, 2018Guru - Experienced User
Did you power down the entire system for 30 seconds then power back on? Then give 5 minutes to wait for the top led to turn on Blue?
You may need to factory reset and set up the system from scratch as last resort.
Any network switches in between the router and satellites? Mfr and model# if you do.
Review this to see if this helps you:
- standarduser73Jul 10, 2018Tutor
No switches to speak of. Ether directly from the router directly to the sattelite. The system has been completely offline for several minutes. The factory reset has been done, multiple times. I had no ether backhaul issues prior to f/w 4.16. This is a new, and very vexing, issue. It is reminiscent of seeing duplicate IPs on the same network, but they aren't duped IPs.
Ok, so after setting up the satellites via wireless first, can you do a IP address reservation on the router for each satellite. Save and apply the setting. Router will reboot I think. wait for ready. I would also disconntect ALL other LAN network devices from the router accept for one wired LAN PC. Then try connecting the wired LAN cable of one satellite and let it re-configure the connection. Wait 5 minutes, You should see the top led turn on PINK, then wait longer, then it should turn BLUE. Test for internet access thru the satellite.
If you can get to this state, then reconnect all other LAN devices to the router.
I presume the satellites are on same version of FW?
