johnny5126
May 08, 2019Aspirant
Backhaul Broke?
Ever since updating from 2.3.1.44 to 2.3.1.60, my ethernet backhaul no longer connects. It only shows 5G backhaul. This happen to anyone else?
May 08, 2019Guru - Experienced User
If it shows 5G then it's working. Unless your RBS is wired?
Has a factory reset and setup from scratch been performed on the system?
- johnny5126May 08, 2019AspirantI have one RBR50 connected in the WAN port going to a switch, and a cable going from the switch to a port on the RBS50. Looking at the connected devices in the past showed wired, but now it shows 5g.
- FURRYe38May 08, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration.
This is ethernet back haul.
Is Daisy Chain enabled? It should be disabled when ethernet connected between RBR and RBS. Under Advanced Tab/Advanced Settings/Wireless Settings
- johnny5126May 08, 2019AspirantThe switch is a netgear jpe16. I have another RBS40 connected wireless ly so don't I need daisy chain enabled? My RBR50 is in AP mode.
- SW_May 08, 2019Prodigy
johnny5126 wrote:
I have one RBR50 connected in the WAN port going to a switch, and a cable going from the switch to a port on the RBS50. Looking at the connected devices in the past showed wired, but now it shows 5g.That seems to be the culprit. The cable should be connected from RBR50 LAN port to the switch. Then RBS50 WAN port should be connected to the (same) switch.
Take a look at this link.
