johnny5126
May 08, 2019Aspirant
Backhaul Broke?
Ever since updating from 2.3.1.44 to 2.3.1.60, my ethernet backhaul no longer connects. It only shows 5G backhaul. This happen to anyone else?
johnny5126
I have one RBR50 connected in the WAN port going to a switch, and a cable going from the switch to a port on the RBS50. Looking at the connected devices in the past showed wired, but now it shows 5g.
May 08, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration.
This is ethernet back haul.
Is Daisy Chain enabled? It should be disabled when ethernet connected between RBR and RBS. Under Advanced Tab/Advanced Settings/Wireless Settings
- johnny5126May 08, 2019AspirantThe switch is a netgear jpe16. I have another RBS40 connected wireless ly so don't I need daisy chain enabled? My RBR50 is in AP mode.
- FURRYe38May 08, 2019Guru - Experienced User
Daisy Chain needs should be disabled.
Ethernet with a switch configuration look similar to this:
Please confirm the model # of the NG switch? JPE16 doesn't pull up.
- Chuck_MMay 08, 2019Mentor
I have RBR50 and three RBR50s... Two RBS50s are hard wired and one is 5G.... Upgrade to firmware V2.3.1.60 and all is working perfectly.
