loomis1975
Aug 10, 2017Luminary
Backhaul Capability of the RBW30 Wall Plug Satellite
https://kb.netgear.com/000038220/Which-Orbi-WiFi-System-is-best-for-me On this chart, it shows the RBK52W as a RBR50 router with 2 RBW30 satellites. Down the list it shows the backhaul antennas ...
- Aug 10, 2017
You are correct, the backhaul is indeed 867 on those units:
https://www.cnet.com/products/netgear-orbi-rbk30-tri-band-wifi-system/review/
Rodney
rhester72
Aug 10, 2017Virtuoso
Rodney
peteytesting
Aug 10, 2017Hero
note - even if the rbw30 had 1733M backhaul it wouldnt be usable as the rbw30 has no ethernet and only wifi and max wifi speed is 867M on 5 gig
