Rmngg
Sep 04, 2020Aspirant
Backhaul instability . RBR50, 2 RBS50 and 1O Orbi Wall.
I have RBR50, 2 RBS50 and 1O Orbi Wall. and 36 attached devices, 10 wired 26 wireless. Most of the time I have GOOD reading on Backhaul between RTR (Router Firmware Version V2.5.1.16) and all 3...
CrimpOn
Sep 04, 2020Guru - Experienced User
Rmngg wrote:Also is it possible to send a reboot/sync signal to remote Sat's? Or I guess I could walk around house and power off/on.
Yes. Each Orbi can be set to allow access via telnet. This is an option on the Orbi web "debug" page, http://orbilogin.net/debug.htm.
Once "Enable Telnet" is checked, the Orbi can be accessed by a telnet program from a PC, Mac, tablet, etc. Since my basic platforms are Windows and Linux, I use the PuTTY app (free). It allows me to store information for many servers which I can pick from a drop down menu. (Saves typing) I have one for my Orbi router, Orbi satellite, and serveral other hosts that I sometimes telnet into.
So, telnet into one satellite. Login with "admin" and the web interface password. Type "reboot".
Repeat with the other two satellites.
Is this easier than walking around and pressing the power button? No idea. Since I telnet into my Orbi router at least once a day to check on this and that, it was worth the setup time and learning curve.
The original post did not mention how the satellites connect. All directly to the router or some in a "Daisy Chain"?
