schoolwifi
Oct 29, 2019Aspirant
Backhaul issues in difficult building
I work in an old building with a mix of cinderblock and drywall walls (mostly cinderblock though). We've had issues with wifi forever for obvious reasons, but in 2019 it was decided that we had to fi...
CrimpOn
Oct 29, 2019Guru - Experienced User
One possibility is to connect at least some of the satellites to the router using PowerLine adapters. These use the existing electrical wiring to create a network within the walls. I have four PowerLine adapters in my house connecting Tivo, WiFi access points, etc. (Actually, two of these: https://www.tp-link.com/us/home-networking/powerline/tl-pa9020p-kit/
PowerLine is as esoteric as WiFi. How far apart things are. How many different electrical circuits are involved. For example, I get over 1 gigabit to another bedroom on the same circuit, 380mb to a room farther away on a different circuit, and only 170mb to the garage which is farther still on a different circuit. If your Orbi satellites are "Daisy Chaining", the effective througput may not be all that great, either.
The "good news" is that experimenting with PowerLine will not cost that much. About $300 will get you six adapters. They won't damage the Orbi's or involve tearing up walls. And, if the experiment is a dud, Amazon will probably take them back.
Personally, my choice would be to run ethernet cables down the hallways hidden inside plastic wiremold up near the ceiling. I would probably try PowerLine first, just to determine if it works in your environment or not.
Another thing to check into would be moca adapters. If there's coax ran within the building you could use moca adapers for the backhaul. I've found them more reliable than powerline when it comes to larger buildings.
- CrimpOnOct 29, 2019Guru - Experienced User
Good catch on the MoCHA. I have used that as well. Both of these technologies take advantage of existing wiring. Maybe someone ran coax to all the classrooms in hopes of doing televised instruction years ago, and it is still there.
- schoolwifiOct 30, 2019Aspirant
Thank you! Unfortunately I'm fairly confident that there isn't any coax. It wasn't all that long ago that we got rid of the tube tv's on rolling carts and mounted flat screens or projectors and none of those are wired to anything but a laptop or dvd player.
