Lexkok59
Sep 25, 2020Guide
Backhaul on 2,4 ghz
Since this week my Orbi RBR50 with 2 satellites have a strange thing. 1 satellite has a backhaul of 5 ghz en satellite number 2 just 2,4. I have this set now almost 4 months and it always works wit...
CrimpOn
Sep 25, 2020Guru - Experienced User
This appears to indicate that satellite two is not able to get a good connection with the router at 5G and has changed to 2,4G to get a better connection. Radio signals are very sensitive to building materials and distances. Are you positive that "nothing has changed" about the placement of the equipment or anything in between the units? Sometimes even a small change in position or orientation can make a difference.
- Lexkok59Sep 27, 2020Guide
Thnx for your answer, no nothing has changed in all those months.
