Lexkok59
Sep 25, 2020Guide
Backhaul on 2,4 ghz
Since this week my Orbi RBR50 with 2 satellites have a strange thing. 1 satellite has a backhaul of 5 ghz en satellite number 2 just 2,4. I have this set now almost 4 months and it always works wit...
Lexkok59
Sep 27, 2020Guide
Ok, thnx, is there a way to change that backhaul channell to a different channel?
Sep 27, 2020Guru - Experienced User
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
- tarzan_nojaneSep 28, 2020Star
It can't hurt to factory reset the lone satellite that is having the issue. Re-sync it directly to the router at an initial distance of 10-20 feet and see if that doesn't allow it to connect the backhaul at 5GHz. Give it 10-30 minutes at the closer position to complete syncing, then move it back to its original location.
