CedricJR
Jan 27, 2018Guide
Backhaul quality is horrible
I bought a RBR50 router (configured in AP mode) and 3x RBS50 satellites. To diagnose the problem I switched off all satellites, except one. The problem is that a neighbour is using the exact channel ...
- Mar 28, 2018
Try the beta.
Theres no CLI support.
Vontech615wrote:
I'm on FW 2.1.2.18. Just curious, why Cat6? I have Cat 5e which should be more than sufficient. I have a wireless backhaul, not wired. I'd mainly like to know if there is a way to make more advanced changes via a CLI?
DarrenM
Jan 31, 2018Sr. NETGEAR Moderator
I have sent you a PM
DarrenM
- Vontech615Mar 28, 2018AspirantI'm in a similar situation. Are there command line tools available for the Orbri RBR50?
- FURRYe38Mar 28, 2018Guru - Experienced User
What FW version are you using?
What CAT# cable are you using? CAT6 cabling is recommended.
Is the Satellite directly connected to the router with cabling or is there a network switch in between?
Vontech615wrote:
I'm in a similar situation. Are there command line tools available for the Orbri RBR50?- Vontech615Mar 28, 2018AspirantI'm on FW 2.1.2.18. Just curious, why Cat6? I have Cat 5e which should be more than sufficient. I have a wireless backhaul, not wired. I'd mainly like to know if there is a way to make more advanced changes via a CLI?
