CedricJR
Jan 27, 2018Guide
Backhaul quality is horrible
I bought a RBR50 router (configured in AP mode) and 3x RBS50 satellites. To diagnose the problem I switched off all satellites, except one. The problem is that a neighbour is using the exact channel ...
- Mar 28, 2018
Try the beta.
Theres no CLI support.
Vontech615wrote:
I'm on FW 2.1.2.18. Just curious, why Cat6? I have Cat 5e which should be more than sufficient. I have a wireless backhaul, not wired. I'd mainly like to know if there is a way to make more advanced changes via a CLI?
CedricJR
Mar 29, 2018Guide
FURRYe38wrote:Did you load the new Beta FW on your system?
Not yet. I'll give a try. Where can I find those beta firmware ?
On the download pages I don't see beta firmwares :
https://www.netgear.com/support/product/RBR50.aspx#download
https://www.netgear.com/support/product/RBS50.aspx#download
Note : I don't understand the numbering either, why is the current version 2.0.1.4 which is lower than the 2.1.2.18 which I'm running...
CedricJR
Mar 29, 2018Guide
OK just two clicks away on this forum : https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584/jump-to/first-unread-message ;-)
- FURRYe38Mar 29, 2018Guru - Experienced User
Give it a try. Keep us posted...
- CedricJRMar 29, 2018Guide
I flashed the router and the 3 satellites to the 2.1.3.4. Then I connected the IPTV to 1 satellite and switched off the 2 others.
The backhaul is still on the same 5 GHz frequencies.
The good news is that the IPTV is running since half an hour without a glitch. I'll give this firmware a run for around a week. Then I'll switch on the second satellite, wait a little and then the third one. I'll update this post.
BETA MR 2.1.3 software can be found here:
RBR50 : http://files.netgear-support.com/go/?a=d&i=o3UGoktK40
RBS50: http://files.netgear-support.com/go/?a=d&i=B57FDA46OO
Glad you go it working. Should work better than older FW.
Let us know if you see other issues.
