CedricJR
Jan 27, 2018Guide
Backhaul quality is horrible
I bought a RBR50 router (configured in AP mode) and 3x RBS50 satellites. To diagnose the problem I switched off all satellites, except one. The problem is that a neighbour is using the exact channel ...
- Mar 28, 2018
Try the beta.
Theres no CLI support.
Vontech615wrote:
I'm on FW 2.1.2.18. Just curious, why Cat6? I have Cat 5e which should be more than sufficient. I have a wireless backhaul, not wired. I'd mainly like to know if there is a way to make more advanced changes via a CLI?
CedricJR
Apr 04, 2018Guide
Hi,
Feedback after a few days :
- the beta firmware solved the backhaul issue with the IPTV, I watched TV instead of playing video games (erk !)
- I put back in place all the other satellites and enabled the daisy chaining topology. No issues.
Actually everything seems to work as intended.
