CedricJR
Jan 27, 2018Guide
Backhaul quality is horrible
I bought a RBR50 router (configured in AP mode) and 3x RBS50 satellites. To diagnose the problem I switched off all satellites, except one. The problem is that a neighbour is using the exact channel ...
- Mar 28, 2018
Try the beta.
Theres no CLI support.
Vontech615wrote:
I'm on FW 2.1.2.18. Just curious, why Cat6? I have Cat 5e which should be more than sufficient. I have a wireless backhaul, not wired. I'd mainly like to know if there is a way to make more advanced changes via a CLI?
Apr 04, 2018Guru - Experienced User
Awesome. Glad it's working well for you. Sounds like your not seeing any issues that others are when using network switches then. However your using power line devices so probabaly wont see this issue.
Enjoy now. :smileywink:
