Dream_Designer
Apr 02, 2020Aspirant
Backhaul showing 50% speed
Hello all, I am having 3 satellites and one router, my most far end satellite was not getting connected, so I decided to backhaul just one satellite , after speed test I found that it's showing 50% o...
Dream_Designer
Apr 03, 2020Aspirant
Thanks
@2.4 is Auto and 5ghz is 48 before I set to manual can you explain what does it mean and what is the meaning of unused channel?
Nearby around 8 wifi connections while sitting at home if i search for wifi it get to see 4 wifi names but I dont understand how is this going to effect us as they are not using our wifi
our house is Three floors 3500 sq ft each floor here is the map
top floor has main router and one satellite covering almost the complete area
medium floor = parking with 8 ft height has one satellite which is sufficient for that desired area
Basement = one satellite wired
from where I can disable these?
Dream_Designer
Apr 04, 2020Aspirant
Today I tried to hardwire one of the. satellite to another satellite around 40 ft distance it was showing 10% of the speed
here is my backhaul connection map cat6
Internet - OrbiR50
R-50 - Sat 1 Distance - 50 ft Speed - 50% of actual ( 300 mbps fiber)
R-50- Sat 2 Distance 30 ft Speed - 100% of actual
Sat2- Sat 3 Distance 50 ft Speed - 10% of actual
Sat2 - sat 4 Dsitance 30 ft Speed 30% of actual
Am i. doing wrong connecting this way ? or. any setting which i need to check ?
- FURRYe38Apr 04, 2020Guru - Experienced User
You might bring the distance with Sat1 and 3 closer. 30 feet seems to be good for your envinroment.
- Dream_DesignerApr 05, 2020Aspirant
Since iT backhaul all wires are already grounded inside walls cannot change the distance is there any other war around ?
- Retired_MemberApr 05, 2020
Dream_Designer wrote:Today I tried to hardwire one of the. satellite to another satellite around 40 ft distance it was showing 10% of the speed
Internet - OrbiR50
what firmware are you running?
Firmware Version V2.5.1.8
Dream_Designer wrote:Firmware Version V2.5.1.8
That's your problem
