ThiagoFelix
Sep 25, 2020Aspirant
Backhaul Speed Check
Hello Everyone. I am new to netgear communitty since I have just bought a Orbi 6 AX4200 (RBK752). Setting up the mesh system was easy and everything was ready in a few minutes. The connection ...
Mstrbig
Sep 25, 2020Master
If you look at the specs, there is an + next to it meaning up to or read exceptions, etc. So the backhaul speed connection depends on how far apart the satellite is from the router.
- ThiagoFelixSep 25, 2020Aspirant
I see. So, to reach 2400mbps the sattelite has to be what? 1 foot away from the router?
Is there a way to check this backhaul speed?
- MstrbigSep 25, 2020Master
ThiagoFelix wrote:I see. So, to reach 2400mbps the sattelite has to be what? 1 foot away from the router?
iPerf may show you your backhaul speed.
