PSIU
Apr 11, 2020Guide
Backhaul status indicates poor
i have just bought a Orbi RBR50 with one satellite. I found strange that even though the top satellite LED ring indicating steady blue for 90-180 seconds, the backhaul status still indicating poor. I...
PSIU
Apr 11, 2020Guide
my router is located on the first floor and the satellite is located on the second floor, almost right above the router. would it lose so much signal if only one floor up? I can see the satellite is connected to the router using 5G, is it possible to connect it using 2.4G instead? would connecting to 2.4G make is a better connection?
ekhalil
Apr 11, 2020Master
It depends on the building material in the house.
If the 2.4 GHz band is better the satellite will automatically select it, you don't need to do anything.
Eventhough the link is shown as poor, do you have any degradation in the performance of the devices connected to the satellite? If not I don't think you need to worry about that. It can get better with the the time, the satellite will always try to negotiate a better backhaul channel with the router to connect to.
Please follow the following steps to check what signal strength the satellite sees:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the following command:
- satelliteinfo wifi (or satelliteinfo -d wifi)
- PSIUApr 11, 2020Guide
When i telnet in to the device and got the following figures.
"mac address" : "38:94:ED:0F:C2:92",
"hop" : "1",
"bridge mac" : "38:94:ED:0F:C2:92",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-75",
"backhaul macaddress" : "3E:94:ED:0F:C2:95",
"backhaul phytxrate" : "585",
"backhaul phyrxrate" : "585",
"backhaul parentmac" : "38:94:ED:0F:B5:9A"
I'm currently using a 100M line and when I am connecting through the satellite using my PC or Mac, I am getting a speed results around 65Mbps to 91Mbps randomly when I do my speedtest with Ookla. I am also got a few disconnections between my iPhone and my iPad and my satellite. I have restarted both my devices and see if it will still get disconnect again. Oh forgot to mention, in between first and second floor is concrete, i guess that will absorb quite a bit of the signal and make the backhaul signal to become poor? Thanks so much for helping me.- ekhalilApr 11, 2020MasterYes, -75 dB is quite low and that’s why the link status is considered poor. You need to get the units closer or add a unit in between if you want to improve the status.
The maximum throughput you will be able to get is 2 x 585 = 1170 Mbps out of max 1734 Mbps if you had a perfect link which is not bad at all.
On the other hand, getting between 65-91 Mbps on a wireless device connected to the satellite is very good and I don’t think you need to worry about the link status unless you keep getting disconnections or service interruptions on devices connected to satellite.- PSIUApr 11, 2020Guide
After restarting my iPhone and iPad, no auto disconnection yet these few hours. I have loaded an app all OkaSpeed Test on my iPhone to test the wifi signal. On both router and satellite, I am only getting a signal between -62db to -68 when I am just next to them. could it be something wrong on my setup?
- taylord01Aug 28, 2020Guide
Hi there.
Just found this thread which would be useful for me, as current Backhaul status of Orbi RBR50 Satellite is 'poor'.
Just tried the TELNET command on my Macbook, but "-bash: telnet: command not found" message.
Any other way to check the actual backhaul value of the satellite?
Many thanks
