BillYoung
May 06, 2019Luminary
Backhaul Status of Poor
 To whom it may concern:
 When looking at the connection between my router and satellite, I see that there is a Backhaul Status of Poor.  Short of actually relocating my satellite, is there anyth...
- May 08, 2019FURRYe38: I have applied all of the changes you requested; including repositioning the satellite. Checking the Attached Devices screen shows the Backhaul Status of the satellite as Good. So between all of the changes and the movement of the satellite, it is now back to what I would expect. Thank you for your help in this situation FURRYe38. We can always count on you for assistance.
May 06, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- BillYoungMay 06, 2019LuminaryFURRYe38: To answer your questions: What Firmware is currently loaded? 2.3.1.60
 What is the Mfr and model# of the ISP modem the NG router is connected too? SMART/RG SR360n
 Is the Orbi system operating in Router or AP mode? AP mode
 What is the size of your home? Sq Ft? 1000 sq. ft.
 What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. 40 feet. This has been the distance between them since they were first installed. And I have seen Backhaul Status of Good before this Poor situation arose.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. 3 for 2.4 Ghz and 48 for 5 Ghz. 1, 6, and 11 are all being used by other WiFi neighbors.
 Any Wifi Neighbors near by? If so, how many? 6 to 8 depending on the time of day.I'll try the changes you suggest once my wife stops her working. - FURRYe38May 06, 2019Guru - Experienced UserAlso try moving the satellite a bit closer to see if the status changes any... Need to use 1, 6 or 11 for 2.4Ghz... Was the FW updated thru the routers web page then continue or has a factory reset and setup from scratch been performed since v60 was applied? - BillYoungMay 08, 2019LuminaryFURRYe38: I'll also try what you said as well. To answer your question: the FW was automatically updated through the routers web page and no factory reset or setup from scratch has been performed. I'd prefer not to do a factory reset and setup from scratch if I can avoid it.
