TominVirginia
May 25, 2018Follower
Backhaul status orbi
I am getting a poor backhaul signal reading to my satalite. I moved the satelite from one postion in my home to another and it said good (for maybe a week) now its poor again. I have not moved it o...
May 25, 2018Guru - Experienced User
What is the building materials? Depending on building materials that can effect signal and range. Concrete and steel.
Try setting closer, say 30 feet if possible.
Has a reboot of the system been performed?
Disable MIMO, Daisy Chain and Fast Roaming and check
