TominVirginia
May 25, 2018Follower
Backhaul status orbi
I am getting a poor backhaul signal reading to my satalite. I moved the satelite from one postion in my home to another and it said good (for maybe a week) now its poor again. I have not moved it o...
Joechang
May 26, 2018Apprentice
same issue i am facing now. same location, just after updating firmware, backhaul status changed from good to poor. check/uncheck mumimo,fast roaming, daisy chain, some times it works some times doesnt. so anyway, give up, speed is ok so enough.
netgear software team really slow and not customer-oriented.
May 27, 2018Guru - Experienced User
Try a full reboot of the router and satellite and check the condition. Last resort, factory reset both router and satellite and set up from scratch.
