kensparker's avatar
kensparker
Follower
May 08, 2020
Backhaul Status Poor
I have checked and followed all recommendations for this with my 3-unit Orbi system.  None of them have resolved the issue.  Can anyone please suggest the fix?
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    Is the RBS wired or wirelessly connected to the RBR?
