mingcyu
Jan 23, 2020Aspirant
BackHaul strength numbers?
I followed the instructions per this link https://community.netgear.com/t5/Orbi/Satellite-5ghz-backhaul-details/td-p/1719529 to enable telnet. My backhaul strength showed -4 but the discussio...
CrimpOn
Jan 23, 2020Guru - Experienced User
My signal strength is reported as "54" (with quote marks). I, also, had expected a negative number. I do not think that -4 is even possible because of the restriction on WiFi radio signal strength.
Is the satellite working OK?
When you power the satellite off and then back on again, what color is display on the "ring light" for 10 seconds?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
- mingcyuJan 23, 2020Aspirant
After restarting the satellite the lights flashed blue for a while,than stopped
Then running the commands it still shows
"signal strength" : "-4",
- CrimpOnJan 23, 2020Guru - Experienced User
Let's try a different telnet command:
satelliteinfo wifi
Here's my output from the Router:
"mac address" : "A0:04:60:....",
"hop" : "1",
"bridge mac" : "A0:04:60:....",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-67",
"backhaul macaddress" : "A0:04:60:....",
"backhaul phytxrate" : "975",
"backhaul phyrxrate" : "975",
"backhaul parentmac" : "A0:04:60:...."
What "matters" is the backhaul transmission and receive rates. - mingcyuJan 24, 2020Aspirant
Here is the output for that command
"mac address" : "38...",
"hop" : "1",
"bridge mac" : "38...",
"backhaul rssi" : "-64",
"backhaul macaddress" : "3E...",
"backhaul phytxrate" : "1040",
"backhaul parentmac" : "38..."
Looks like its got the 5 ghz connection rate. The problem I'm trying to solve is satellite placement. My wife isn't keen on the location where I believe it's optimal so I need to be able to move it around and test.
The numbers look similar to what you have- CrimpOnJan 24, 2020Guru - Experienced User
Those number look pretty good to me. It will probably perform well even farther from the router (as far as backhaul speed is concerned).
At least you have a 'tool' to use rather than simply, "is the light on top blue or amber?"
