mingcyu
Jan 23, 2020Aspirant
BackHaul strength numbers?
I followed the instructions per this link https://community.netgear.com/t5/Orbi/Satellite-5ghz-backhaul-details/td-p/1719529 to enable telnet. My backhaul strength showed -4 but the discussio...
mingcyu
After restarting the satellite the lights flashed blue for a while,than stopped
Then running the commands it still shows
"signal strength" : "-4",
mingcyu
Jan 24, 2020Aspirant
Here is the output for that command
"mac address" : "38...",
"hop" : "1",
"bridge mac" : "38...",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-64",
"backhaul macaddress" : "3E...",
"backhaul phytxrate" : "1040",
"backhaul phyrxrate" : "975",
"backhaul parentmac" : "38..."
Looks like its got the 5 ghz connection rate. The problem I'm trying to solve is satellite placement. My wife isn't keen on the location where I believe it's optimal so I need to be able to move it around and test.
The numbers look similar to what you have
- CrimpOnJan 24, 2020Guru - Experienced User
Those number look pretty good to me. It will probably perform well even farther from the router (as far as backhaul speed is concerned).
At least you have a 'tool' to use rather than simply, "is the light on top blue or amber?"
