ekhalil's avatar
ekhalil
Master
Sep 16, 2018
Backhaul wireless network
Orbi is Tri-Band system. 3 bands are used: 2.4 Ghz band and two 5 GHz bands. I thought that the second 5 GHz band is used for the backhaul network.
Looking into the attached devices in orbilogin I see that the MAC addresses of the 2.4 GHz interfaces of the satellites are shown (connecting the satellites to the router) which I interpret as the 2.4 GHz network is used for the backhault network which is a bit wierd since this is a slower network and has less throughput.
Anybody has better knowledge about this?
Thank you
  • The 5Ghz back haul radio information is hidden and is the wireless backhaul.
    • ekhalil's avatar
      ekhalil
      Master
      Thanks,
      This is what I also think, but every nodes has 3 MAC addresses, why is the MAC address of the 2.4 GHz interface is shown as the backhaul interface between the nodes under <attached devices>?
      • FURRYe38's avatar
        Guru
        Not sure. maybe a cache or mis-naming problem in the UI. Others have reporting seeing the satellites in the connected clients list before rather than in the connected satellites list.
        Seen in different browsers?
        Might try a reset on the router and set up from scratch...Re-add the satellite and check...
