florini
Jan 13, 2018Aspirant
Bad connection near satellite
Hi, I bought my devices about a year ago. I have the RBS50 satellite installed 2 plaster walls away from the RBR50 router, about 10 meters. Everything went fine until a couple of months ago. D...
DarrenM
Jan 16, 2018Sr. NETGEAR Moderator
What firmware version are you on? do you have beamforming and mumimo enabled? have you tried to adjust the wireless channels on your router?
DarrenM
- floriniJan 16, 2018Aspirant
Hi!,thanks for the reply!
I am on V2.1.1.16.
I have MU-MIMO and BEAMFORMING enabled.
I did not experiment with the channels, I can try that.
Florin
- floriniJan 21, 2018Aspirant
... on the other hand, is there a way to diagnose what exactly is wrong with the connection?
Is there a great way to extend the range of my WiFi, using other types of devices?
