Arjan1000
Jan 17, 2017Guide
Bad connection to IOS devices
On every IOS device I see the full strong wifi signal. But when using the internet on these devices it takes a very long time to connect. This is visible with the ios-icon next to the wifi-icon as th...
Arjan1000
Jan 19, 2017Guide
Thanks for the replys. My rma time is almoat gone that's why i returned the product. Still think it's a very good product but unfortunately not on this moment. Will try again in a couple of months with jopefully better results
- DarrenMJan 20, 2017Sr. NETGEAR Moderator
Hello JMU1998
I have informed engineering of the threads with speed and disconnect issues and it is being worked on.
DarrenM
- brasaxJan 23, 2017Apprentice
Just bought Orbi and using it for a week or so.
I'm facing the same problems with disconnects. My iPad Mini 2 connected in 10 hours 97 times as I wrote here already. Same is happening with other iOS devices. Also sometimes my iPhone 7 just looses the connection and falls back to cellular for a minute and reconnects. This is really a big issue as this can cause problems for people not having big data plans.
Another important thing is that the logs from Orbi does not show to which network (2.4 or 5 Ghz) and to router/satellite the device was connected.
Please get this issue fixed asap!!
- Mikey94025Jan 23, 2017Hero
brasax, for now you can go to this URL (posted by someone else recently) and see which devices are connected to which router/satellite and by 2.4/5 Ghz: http://orbilogin.net/DEV_show_device.htm
- TingyunliuFeb 17, 2017Star
do we have any update on this issue?
- DarrenMFeb 21, 2017Sr. NETGEAR Moderator
NETGEAR is aware of an issue affecting some users where wireless client devices frequently disconnect/reconnect from the Orbi WiFi network. We’re actively working on the issue and hope to have a solution soon.
DarrenM
