mainhattan
Sep 16, 2021Aspirant
Bad performance Orbi RBR20 with Unitymedia / Vodafone Station
Hi, I am using a Vodafone Station with an Orbi20. Lately the wifi performance has dropped from about 200 to 50, whereby I signed up for a 500 line. Please advise if you are experiencing simil...
Sep 16, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- mainhattanSep 28, 2021Aspirant
Thanks for your feedback.
I am actually on the latest firmware version: V2.7.3.22
It seems to be that devices connect to 5G only if the device is really close (2m) to the Orbi. Otherwise the device will connect to 2.4G. Therefore the measured performance is very limited. I assume that the firmeware update has caused a different behavior as previously.
Thanks & best regards
- FURRYe38Sep 28, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed?
Please give feedback to the other questions...
Yes - no changes and a friend of mine is facing the same issue.
FURRYe38 wrote:What Firmware version is currently loaded?
V2.7.3.22
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Vodafone Station
130 sqm
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡app. 10 meters each
no changes
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settingsno changes
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- FURRYe38Sep 28, 2021Guru - Experienced User
So does the ISP Modem have a built in router and wifi already?
Do you have Armor or Circle enabled on the RBR?
FURRYe38 wrote:So does the ISP Modem have a built in router and wifi already?
Yes, it does.
Negative
