mainhattan
Sep 16, 2021Aspirant
Bad performance Orbi RBR20 with Unitymedia / Vodafone Station
Hi, I am using a Vodafone Station with an Orbi20. Lately the wifi performance has dropped from about 200 to 50, whereby I signed up for a 500 line. Please advise if you are experiencing simil...
mainhattan
Sep 28, 2021Aspirant
Thanks for your feedback.
I am actually on the latest firmware version: V2.7.3.22
It seems to be that devices connect to 5G only if the device is really close (2m) to the Orbi. Otherwise the device will connect to 2.4G. Therefore the measured performance is very limited. I assume that the firmeware update has caused a different behavior as previously.
Thanks & best regards
Sep 28, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed?
Please give feedback to the other questions...
- mainhattanSep 28, 2021Aspirant
Yes - no changes and a friend of mine is facing the same issue.
- FURRYe38Sep 28, 2021Guru - Experienced User
Really doesn't help answer questions that were asked.
So try reverting FW versions then.
